Fu Manchu
- Mar 18, 2006
- 17,890
- 22,549
- 113
- Location
- WA.
- VZ Crewman, VZ Cross 8, & ya mum.
I have been having some issues with the door lock actuators. The old actuators packed it in so I got some new ones (black widow). Now they work ok but were machine gunning. checked clearance and all was good.
The issue was when I arm the alarm, the locks opened. When I disarm the alarm, the locks close The opposite of what should be happening
So I swapped the two wires that open it so I reverse the current for the motor. I stopped the machine gunning but the same thing still happens It is the opposite of what it should be.
The wire colours are identical on the old solenoid and new. There is blue and green then on the drivers door there is the additional three wires. They are white, black and brown. I swapped the brown and white but just got a funny noise from the lock actuators and then just got machine gunning
So I have ripped open the old actuator to see how it works. As I thought, there's the two wires going to the motor and then there is a switch that the other three wires go to. It looks much like this one in the diagram
So can I change the way the wires go in to get the locks to open and close as they should?
The old switch from inside the actuator.
