vy calais hoodlining in vt(loom problem)
qik42c
vtss series 1
Ok guys and girls,im in desprite help of finding out how to connect wires in to me putting in a vy/z calais roof lining and light set up,the roof lining consists of having the lights in the back plus the sunglasses holder in the front and i want them to work like the normal light set up i had in the middle originally,the wire on the vt loom consist of the following
vt loom for harness
orange/black
yellow/green-blue
purple = 5 wires
black/blue
white green
vy/z loom to roof harness
orange/black
yellow /green
purple = 6 wires
white/green
black/green
white
has any 1 done this conversion and know how to connect these up so my roof lights work when the doors open and when i push the button on the centre sunglasses holder to full on postion that it will work,i have seen a thred on how to install a sunglasses holder in to a vt but only describes on how he made his own harness from the centre original light...need help as im sick of driving around with no lights
PLZHELP...CHEERS
qik42c
vtss series 1
bump,anyone.....
Zeussy
SSM11K
Central Coast
Gen-F Clubsport, Rodeo 2.8 TD 4x4
You will need the Wiring Diagrams out of the VT, and VY models, then compare/crossmatch each of them off to each other...
Otherwise you would just be 'guessing' hooking one wire up to another...
I could probly get my hands on a VT wiring diagram for you, if it helps any? Let me know... :beer chug:
I've put a VZ harness, lining, and light setup in my VY, but it plugged straight in, so im unsure as to 'what goes where' :hmmm:
caaf
Melb, Vic
www.aurfscan.com.au
VYII Equipe S/wagon V6
Hope this helps ;)
Just remember that things are negatively switched. I'm sure once you start putting a test lamp on things you'll see the light (pardon the pun) ;)
  • interior illumination.pdf
Thomo92
Toronto NSW
VT Series2 Acclaim
Same problem
vt loom for harness
orange/black
yellow/green-blue
purple = 5 wires
black/blue
white green
orange/black
yellow /green
purple = 6 wires
white/green
black/green
white
PLZHELP...CHEERS
Did you by anychance have any luck with figuring this problem out? I have same drama and can't stand not having it all finished off immediately
Please help somebody, desperate!!!!
