Hi,
When I turn the Key to Ignition the instrument panel does not light up on the dash, I can still start the car and run it but when i put it on ignition none of the lights come on, When i start the car the gauges work such as the tacho and speedo etc.
Is there some sort of fuse that could be blown causing none of the lights to come on for the dash cluster?
Thanks.
Thanks.
