VP Instrument Panel
blackshuck
VP Executive
I'm having the usual instrument panel issues eg. fuel/temp guages sticking, but i've also got the speedo, odometer and back lights no working. I 've had the panel out and checked as best i can all the relevant fuses etc Any ideas would be greatly appreciated, as well would I be able to replace the panel all together with say a VR/VS panel ? Cheers fullahs
markovr
62
northside brisbane
youtu.be
07vessv 94vr .04vz wgn,93vp wgn,82 vhV6 wgn 88 vn
fuel temp gauges normally stick because voltage regulator solder joints have a couple of dodgy joints that need resoldering ......you need to pull the cluster apart to find the small printed circuitboard inside...remove and resolder connections.
Dont try to connect a vr/s cluster in a vp...it will burn out and total the cluster and maybe damage your wiring.
