absolutly stummped! :(
JEZIMP
VT ll S Pack
my vt has jsut started doing this very recently, and nothing else is out of the ordinary. my high/low's dont seem to work, my parkers work, and when i use high beam, the high lows come on like there spose to, but they just dont work by them selves :S no fuses seem to be blown, any ideas? driving at night is really really hard lol
scozz76
Largs Bay, Adelaide, S.A
VF 2014 Evoke - VYII Acclaim
Start with the basics. Seeing as you've checked the fuses, check the relays. Make sure all connections are clean (bad grounding creates strange problems).
Check the switch and battery earth.
chief18
nil
I'm abit confused by high/lows.
But as scozz76 said, check relays and connections. Could also be a problem in the switch itself or the globes.
AJ-VL-23
34
Redcliffe, Western Australia / Wiluna, North Weste
www.facebook.com
82 VH Commodore 202
indicator stalk? i know that if that happens in the old commo's it means the indicator stalk is buggered, the run the feed from the lights through the switch that activates the high beam so when it breaks the low beems stop working but the high's still go
