madreader222
Aero Rules
We have just got home in limp mode and we have code 42 coming up. Any help with much appreciated.
Given the history with the code 14 as well my guess is an ECM fault. The ECM's are cheap enough - as little as $20 used - that it might be worth the guess. Swap (keep) the MemCal though.
Maybe: http://forums.justcommodores.com.au/vn-vp-holden-commodore-1988-1993/65748-fault-code-42-a.html , post #9 if you want to perform more checks.
