+ Reply to Thread
Results 1 to 14 of 14
Thread: Camera for commo/float (not reversing camera)
    VZ Executive
    Sep 2009
    Sydney, NSW
    Question Camera for commo/float (not reversing camera)
    Can anybody recommend a camera to be placed into my horse float so i can view the horses while im driving??
    Any info would be greatly appreciated!!
    calais24/7's Avatar
    calais24/7 is offline Mucca Mad Boys calais24/7 Executive
    VS Calais II 5L, 98 rodeo v6
    Jul 2009
    Quote Originally Posted by Shelz View Post
    A baby monitor could work or there are DIY security kits from bunnings and dick smith you could try.
    VS Acclaim V6
    Jul 2006
    HakHawk should be able to help you out here he has done something similar to a customers float
    03 VY Supercharged 3.8L
    Stack The Cats Champion!
    Nov 2008
    Tullamarine, Vic
    Somthing like this?
    Gator Hybrid Wireless / Wired Selectable Reversing System (L6050) | Dick Smith Online Store (AERPro are the manafacturers)
    Otherwise Colour Wireless Reversing System (L6112) | Dick Smith Online Store ?
    The Gator one i have seen installed on a VE commodore and it was good quality (running through wireless). If you head to a larger store they might even be able to discount a bit more.
    Luke0011 is offline Car Audio Installer Luke0011 Hitchhiker
    VZ Berlina 2005
    Jan 2007
    i would suggest an infrared ccd camera for the highest quality and brightness in a dark enviroment.
    around 300.
    VZ Executive
    Sep 2009
    Sydney, NSW
    Quote Originally Posted by alien View Post
    Somthing like this?
    Is it a reversing camera or an actual camera so i can view the horses??
    VZ Executive
    Sep 2009
    Sydney, NSW
    Quote Originally Posted by ephect View Post
    Thankyou! HakHawks advice was very helpful!!
    accentstencil's Avatar
    accentstencil is offline Donating Member accentstencil Maloo accentstencil Maloo
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    A reversing camera is simply a normal camera facing the rear, so a good quality reversing camera will do the job, all you need is a monitor to connect it to. You can get a 7" monitor at Big W for $70-$100 depending if it is on special or not.
    Here is the camera I bought a couple of years ago and I am very happy with the picture quality, especially for the price. It has a Sharp 1/3" image sensor unlike the cheaper cameras which use CMOS.http://cgi.ebay.com.au/A56-License-P...item4ced12738b
    Here is one of the same quality but with infra red for night vision.http://cgi.ebay.com.au/SUPER-HEAVY-D...item45f069f96d
    You might want to get one with infra red if you plan on using it at night. Mine does not have infra red but since I use it as a reversing camera I find the reversing lights light things up really well.
    MY RIDE
    2005 VZ SV6
    Jun 2009
    Australian Crapital Territory
    If he got a reversing camera though, would there be a way he could make it be on all the time and not only when reversing?
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by Maxxiz View Post
    Yes, mine is on all the time, it is connected to my GPS navigator and I press the A/V button when I want the camera. Instead of connecting the power wire to the reversing lights you connect it to somewhere that gives you power when the ignition is on.
    MY RIDE
    VY SS
    Jun 2006
    Albany
    try looking for a reverse camera setup which are used for caravans, these usually have a camera mounted on the back of your caravan and have a plug setup on the car and caravan so it can be unplugged. you could easily just mount the camera in the trailer, most of these reverse camera setups just use the reverse light wire to tell it to turn on but you can just wire it to any power source like an accessory feed or maybe use your parklight wire so you can turn it on by just turning your parklights on
    VZ Executive
    Sep 2009
    Sydney, NSW
    hakhawk's Avatar
    hakhawk is offline forum adjudicator hakhawk Grange hakhawk Grange hakhawk Grange
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    VZ Executive
    Sep 2009
    Sydney, NSW
    I'm Going with the camera and monitor from Autobarn, thats the one i liked the most!! Haven't had a chance to install it yet!!! Cost me about $438.00.
+ Reply to Thread
  1. Reversing Camera
    By Scotty_Doesn't_Know in forum VE Holden Commodore (2006 - ?)
    Last Post: 26-08-2011, 05:17 PM
  2. Reversing Camera - what camera to get and where to connect my reverse wire?
    By ozzie_online88 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 02-07-2008, 02:27 PM
  3. Reversing camera
    By hako in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-04-2008, 09:34 PM
  4. SLR Camera
    By minux in forum The Pub
    Last Post: 18-03-2008, 03:22 PM
  5. Need help with new camera!!
    By AirStrike in forum The Pub
    Last Post: 21-11-2005, 10:40 PM
