combatantsomeone
- Feb 12, 2008
- 150
- 0
- 0
- Location
- Gold Coast
- VR Acclaim v6..?
Ok
had the car running, switched it off and went away came back and it wouldnt start. Fuel pump would prime just wouldnt kick, tested starter motor and ran a wire to the starter motor works ok. problem is that the starter relay is getting no power (violet/purple wire?) anyways pulled the steering surround off and checked the wires on the back of the keybarrel, all had power at varying stages of key rotation except a big fat purple one (same colour as one at starter relay). Also door locks dont work and the light doesnt come on wen the door is opened and no indicators or hazards. Now it wont even prime the fuel pump and there is no power to the EFI or Fuel pump relays. Someone i talked to mentioned that it could be the BCM? or perhaps some form of factory security system? theres a small module on the passengers size a bit bigger than a matchbox with 1 plug in it could this be something to do with it?
Any help is much appreciated
