justin35
- Jan 30, 2010
- 35
- 0
- 0
- Location
- Adelaide
- VT V8 berlina
Gday guys im new here and would like your help with a problem im having with my vr,its a v6 and auto,some reason it keeps blowing the fuse(number 12 fuse)for the trans control.when it blows the trans goes into limp mode only top gear and check engine light comes on,i had a look under the car and found that there is a plug in the back of the trans covered in tranny oil(i think this is the trans control module i dont know???)wen i pulled the plug it was covered in oil inside the plug were the connections are,,leave the plug of and the trans only goes in 1st gear and reverse??would i be right in thinking that this connection been covered in oil was causing it to blow the fuse and only needs the module and or seal replaced(looks to be only a single bolt holding it in place),,,anyone else had this problem,your help would be gratefully appreciated..
