Results 1 to 3 of 3
Thread: VS Commodore Wiring Diagrams
    VY 5.7
    Apr 2006
    Default VS Commodore Wiring Diagrams
    Hi,
    I'm looking for a wiring diagram for a VS Commodore.
    They seem to be hard to come by.
    None of the boot lights are working. Seems to be an earthing problem.
    Any help would be gratefully appreciated.
    Regards,
    Neil.
    94vr 5sp .04vz wgn,93vp wgn,82 vhV6 wgn ,88 vn 5sp
    Nov 2003
    northside brisbane
    Looks like if its factory fitted, the earth for the tail lights in the boot goes back via a black wire (theres no actual earth lug that goes under a screw in the boot) that runs back to the front of the car and that goes through the multipin connector under the right hand kick panel to then feeds the bcm ...the earth point on the body near the battery connects to the bcm to provide the circuit to earth the tail lights when the bcm enables it ...part of the auto lights off feature... for the 12v+ feeds to the tail lights under the steering column fuse 1 feeds the parkers and fuse 8 feed the stop lamps
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
    Devils_Thunder's Avatar
    Devils_Thunder is offline Riding high...
    2010 Captiva.....
    Jan 2009
    Wahgunyah, NE Victoria
    Grab yourself one of these...
    VR VS Commodore Workshop Manual V6 V8
LinkBacks (?)
  1. vl wiring diagrams
    By Panama in forum Electrical Wiring / Questions
    Last Post: 01-02-2010, 10:54 AM
  2. VT wiring diagrams?
    By smith#29 in forum Electrical Wiring / Questions
    Last Post: 05-09-2008, 10:47 AM
  3. VS ECU and BCM wiring diagrams.
    By westic in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-02-2008, 06:20 PM
  4. Late model Commodore Wiring Diagrams
    By Calaber in forum Electrical Wiring / Questions
    Last Post: 29-11-2007, 07:07 AM
  5. Holden Commodore wiring diagrams up to 92
    By 1redVN in forum Electrical Wiring / Questions
    Last Post: 09-02-2007, 07:58 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97
