gelousi1
- Feb 10, 2010
- 8
- 0
- 0
- Vr Berlina 195i
Hi guys new to the forum
My Vr Berlina has had the engine check light on since ive bought it, its got a fully manualised auto which is also shift kitted, its the hsv cluster cant remember if its the 220k or 250k but its really annoying. Last night went into diagnostic mode and as soon as i turned ignition on i noticed the a/c thermo switched on and the climate control was off, apart from that first i got 12 which is ok then i got a 59 which has got me stuck i searched 59 and it means
Transmission Fluid Temperature -auto trans code Voltage High
even if its started first thing in the morning that comes up, is there a temp sensor on the auto or what is usually caused this problem?
thanks
thanks
