Mick1988
W.A. Cruise Moderator
- Apr 6, 2008
- 786
- 14
- 18
- Age
- 35
- Location
- Perth, Western Australia
- Website
- www.sarichtechnology.com
- Too many to list......
Hi guys,
I have a VX Series II Executive. I am also wrecking a VX Series II Berlina. I have taken the Power window looms, regulators and switches from the Berlina and installed them into the Executive.
All works great, except my driver's window won't go up or down. I know for a fact that there is nothing wrong with the switch or regulator so I am assuming it's related to my BCM being unable to handle the express down feature.
So I've decided to swap the BCM from the Berlina into my car. I do have a few questions first though.
1. Does the Berlina have the highest possible BCM? I.E. if I wanted to install options out of a Calais or Statesman in the future would the Berlina BCM handle them?
2. The BCM is behind the passenger side kick panel, correct?
3. Will the Berlina BCM fit straight in and use the existing plugs that are already in my car?
4. Will the Berlina still start and drive without the BCM allowing me to demonstrate the motor or do you need a BCM installed to start and drive?
Thanks in advance for your help!
