+ Reply to Thread
Results 1 to 10 of 10
Thread: VX starts OK, but wont start again when hot
    VX
    Mar 2010
    Default VX starts OK, but wont start again when hot
    My VX starts OK when cold. When I do a 50-70km journey it wont start after stopping. Cranks a few times then is dead. Car cools down, starts fine. Battery, starter motor? Would appreciate any solutions.
    '97 VS Commodore + '98 E36
    Apr 2005
    sounds like tha CAS - Crank Angle Sensor, which can be located behind the harmonic balancer (big main pulley on the bottom of the engine) you wont be able to see it clearly as you need to remove the balancer to get to it.
    You should do a Error Code Check first, so you can determine for sure and then When this happens again pour some water behind the pulley so it wets the CAS and see if it starts up again, if so you need to replace the existing CAS
    VX
    Mar 2010
  4. Default
    do you mean the motor won't actually turn over at all when hot? i've had the same problem since i got my car, there have been a couple of times were i've gotten stuck because i couldn't start my car. since replacing the battery and installing a big fat ground to engine bay i haven't gotten stuck anywhere, still cranks a little bit slower when hot but it's liveable.
    take it down to a mechanics/auto elec, they will test the battery and let you know if it's stuffed or not. basically if they put a new battery in and it starts, problem solved. if it doesn't start then don't buy the battery . win win
    Quote Originally Posted by zai View Post
    I am not sutpid
    Blown VT Commodore
    Jan 2008
    NSW
    Quote Originally Posted by Revival View Post
    Thanks ridah. That doesn't sound like a cheap fix!
    I have the EXACT SAME problem. And the cold water trick works a treat. Pour it on there and wait a minute or two, allow the CAS to cool and it will crank over.
    My mates a mechanic and is fixing my car tomorrow. $45 for the CAS $0 for labour yay. If you go to a mechanic and he charges you over $100 he's ripping you off. I let you know how it goes with my car.
    cheers
    Kernal
    VX
    Mar 2010
    Yesterday when I tried to restart it, clicking noises came from under the dash. This morning it tried to crank, maybe a turn and then clicking noises. Taking it to the auto sparky tomorrow after a long run. His diagnosis over the phone was "starter motor failing when hot."
    VH and VT S2 Berlina ecotec
    Aug 2007
    Brisbane-northern suburbs
    im 99% sure it'll be the starter motor, they are fairly cheap for commodores. vt's and vx's have that problem with them, mine did till i replaced the starter motor now its mint
    Blown VT Commodore
    Jan 2008
    NSW
    That clicking means your battery is dead. Do u have jumper leads or a battery booster. Was the engine hot when u tried to start it? Then its not "wont start when starter motors hot". Im 99% sure hes takin u 4 a ride.
    Aug 2007
    yeah putting a jumper battery on it will start it but the problem will still be the starter motor (assuming the battery is ok) when they get old they draw alot more current so it will seem like u have a dead battery.
    VX
    Mar 2010
    Arrived home Friday nite after 70km drive. Shut it down, started straight away. No probs. Took it to the electrician Sat morning and battery is just fine, good charge started with minimum of fuss. Pointing towards a dodgy starter motor. Thanks to everyone for help.
+ Reply to Thread
  1. Car Wont Start on 1st Crank But Starts on 2nd
    By oztech007 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-10-2010, 06:33 PM
  2. Testy car starts one day, wont the next!
    By belle007 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-12-2009, 06:01 PM
  3. VT SS LS1 wont start
    By nemesis_adrasteia in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-11-2009, 06:31 PM
  4. VR wont start
    By Rumbl in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-01-2009, 12:35 PM
  5. Another VT that Wont Start
    By robbo5253 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-01-2008, 07:12 PM
