KRUPTD
VN BT1 5L
- May 7, 2007
- 316
- 4
- 0
- Age
- 41
- Location
- Griffith, N.S.W
- VY SS Crewman,XE Falcon,HJ V8 panel van,HZ tonner
Ok,i have fitted a VP 5L/turbo 700 into my fiances HZ tonner.I'm at the stage to fire it up.
I'm missing injection pulse,im also using the VP loom in the engine bay which also goes through the fire wall (VP commodore).My computer is mounted in the engine bay.
Now that im using the VP loom i didnt get the anti theft module and remote/key.
Can anyone help me out to which wires i bridge on the ecu or loom to switch the ECU on so i will have injection pulse?????Maybe a small wiring diagram...
Also i have spark and my fuel pumps also run,this tells me that the ECU is switched off and the injectors are operated through the ECU.Also my engine light doesnt work either maybe due to the fact the ECU is off...
When i mentioned i ownly have the engine loom,it ownly goes to the ECU and then 2 white plugs not far from the ECU plug,one of which is the diagnostic plug and the other i do not know...
Your help very much appreciated...
cheers Bryan
cheers Bryan
