I'm currently running a VN loom and computer in my VR. So far only two issues - 1. Fuel pump relay had the wire on a different pin on the plug connecting the loom to the under bonnet relay box. Easy fix, just pulled the wire out of one side of the connecter and put it in the right place to match the other side of the connector plug.
2. Haven't found the wiring for the speedo yet, but this is more slackness on my part not spending the time to trace the wiring yet.
I've got the wiring diagrams for VN v8 and VR V8, if you want them. But you can get them (plus the VS V8 one I guess) from Doctor Bob's website "Rob's Creative Calibrations".
I found that most wiring colour coding, and pin assignments, were the same between VNV8, VRV8, and VRV6. Presumably they are standardised, and hopefully will be much the same on the VS too.
*Edit - should have mentioned the obvious - I'm running a 5lt from a VN too, not just the loom and computer. Although previous owner told me the motor itself was originally from a VR.
Mind you, he probably would have also told me the tooth fairy is real if he thought that would help make the sale...
