VT PCM does not use a kickdown switch or external signal to trigger a gearchange.
Gear changes are calculated by the PCM software internally using engine load, temperature, shifter position and various other sensors.
Wiring diagram for the trans itself is very basic. Google VT ECU wiring diagram
