catzbratz3
- Apr 1, 2010
- 3
- 0
- 0
- VR Statesman & BA XT
hi all
just got a vr statesman and when i go to turn on the headlights to parkers, they dont turn on neither do the taillights or dash lights..... yet the normal head lights work and so does passenger high beam....
i checked fuses there fine and if i run direct power to the fuse under dash parkers/ tail lights/dash work but nothing when i turn the switch.... now could it be the head light switch....tried all relays and fuses even replaced stuffed plug on drivers side headlight now have high beam...... i think it may be bummed wire from switch to fuse box as i replaced switch now with new one
or should i be checking wires behind the fuse box
cheers in advance for any ideas or advice
christel & paul
christel & paul
