Results 1 to 3 of 3
Thread: Reverse Parking Sensors
    Shounak's Avatar
    Shounak is offline The Kicking Horse
    VX Executive S2 + XF Panel Van Project
    Apr 2005
    Default Reverse Parking Sensors
    i, I just purchased some reverse parking sensors, but the display is on the mirror. It clips onto my rear view mirror and when I'm in reverse shows up as as an LCD image on the mirror. Installing them seems like a bit of a bitch.
    Drilling the holes and putting in the sensors is fine, but it's the rest of the stuff I can't do. I'll probably need an auto sparky to run the wire from inside the roof trim to the boot, connect wires from the sensor hub to the reversing light and to connect the detectors from inside the rear bumber to the hub.
    Anyone have any idea how much this should cost? If I do the drilling myself.
    It's actually meant to be DIY kit, but I'm clueless when it comes to anything electronic..
    vlv8vic's Avatar
    vlv8vic is offline <---Brad Quaid = internet stalker
    M5
    Mar 2005
    Australia
    it should be pretty much connect A to B job. the hardest bit might be taking off trims to hide wires. instructions are usually pretty reasonable with those.... (unless its a terrible translation....)
    Shounak's Avatar
    Apr 2005
    Quote Originally Posted by vlv8vic
    How do I take off the trims? Is there a certain way to do it?
    Also does anyone have any idea on how to hook up those two wires to my reversing light?
    The instructions don't cover these..
  1. Reverse sensors for vz ute - crewman
    By matt8 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 22-07-2006, 08:24 PM
  2. Replies: 1
    Last Post: 09-07-2006, 08:39 PM
  3. Reverse parking sensors
    By shrapnel in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 16-05-2006, 11:46 PM
  4. Reverse parking sensors..
    By Shounak in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-08-2005, 07:05 PM
  5. Reverse Sensors
    By Ratty in forum VY Holden Commodore (2002 - 2004)
    Last Post: 18-03-2005, 05:32 PM
