badger__rox
- Mar 8, 2007
- 121
- 0
- 0
- Location
- Cranbourne
- VnExecutive
hey guys so ive converted my vn to an rb30 turbo its all basically there just trying to wire it all up,
i have power to all the inside of the car headlights and every thing it cranks but i have no fuel i have found a plug on the original wiring lume the when you cross to wires it pumps fuel so my question is
how do i wire it up?
also the extra pump that vls have under the car should i just split the flue hose fit it before the fuel filter and just tap off the other wires for the intank pump or will it need more power (as in voltage)?
also the there is 2 plugs on both the vl engine lume and vn lume just on the inside of the fire wall before the ecu ive done a heap of reading thru ecectrical books but havent had much sucessworking out what they do..
any help will be much appreciated..
