grnvs
- Sep 10, 2006
- 125
- 0
- 0
- vs v8 5spd 9c1
Hi. I posted this thread in the electronic section and someone suggested I talk to you guys about this one.
I have cruise control on my car, it a factory unit rigged up to my 5ltr. I have a T5 manual gearbox so it has an actuator on the clutch peddal to disengage when pushing the clutch in. Anyhow, the thing works fine with my level 2 dash cluster, but as soon as I put in my new level 3 cluster (I have the trip computer all wired in too) it will not activate. I can switch the cruise control unit on, as the crs light comes on, but it will not engage. When I press the set button, the on light briefly flashes up but wont stay on and the cruise wont engage. I have reswapped the clusters in and out to confirm it is the issue and it definately seems just to not want to work with the L3 cluster!
I'm a bit stumped. I checked the wiring diagrams and the green wire which comes from the dash with vehicle speed data is supposed to also make the spped alert work. The weird thing is the speed alert does work on the L3 dash and if the cruise control speed is taken off the same wire why does it not work? And i guess the wiring to the cruise control module works because the whole thing is fine with the L2 dash!
Any help is much apreciated.
Peter
Peter
