a1k3m1
- Feb 3, 2010
- 359
- 1
- 0
- Location
- Central Victoria
- 2003 VY II S-Pack 25th Anniversary
Hey guys, I got a question for yas about running a set of undercar lights .. Yes, i know their illegal and all so thats why im not going to drive on the streets with them (just on the racetrack and whatnot).
But what my idea is, is to install the lights under the car and somehow run a wire into the cabin somehow and tap into the interior lighting circuit, and then run a switch (so they can be permentally turned off).. So what happens the lights under the car switch on when the door and stuff is open then switch off when the door is closed..
So im lost on how to wire these up, should i run a relay system and give the lights their own circuit? or just run it straight from the interior lighting one,, The lights are just 2 30 LED light strips so 60 LEDS all up, im thinking this should be okay, but just wanna make sure.
and also where would be the best place to tap into the interior lighting circuit .. is there any wires near the driver kickpanel that i could use?
Thanks again Guys!
Thanks again Guys!
