It's a fantastic idea, and one of the first things that anyone will do to their car when they want to start getting the best out of it. As moose man said, get a fat wire, (4g or bigger), and run that from the negative of your battery to a big fat bolt that connects to your chassis. Drill a new hole if needed. I would suggest finding something as close to the battery as possible, but I don't think is matters a great deal if it's on the other side of the engine bay.
Sand back the paint so that you reveal the metal, and you will be in business.
And to re-iterate, make sure you find a bolt that is connected directly to the chassis, if you connect to a bit of metal that is welded to the chassis, then you are pinning your hopes on that weld being 100% solid and conductive, which sometimes might not be the case, so direct to chassis is the desired connection point.
Denno
