claytonsmechanic
Hi all, brand new to the site. I have a problem with my VX front park lights not working. I have the whole front end off for other reasons, and have the whole front left headlight assembly removed. The fuses are fine, I am getting power to the light bulb, new bulbs installed, but lights not working. Not exactly sure how long they've been out for. I thought it must be an earth problem, because my power indicator light was showing power to the bulb but the light was not on. Being the auto-electrician (NOT) I thought about trying to run another earth for the light to see if that was the problem. Which I did (wire to touching the bulb and earthed to the chassis) with the power to the assembly disconnected because I was getting sparks. But get this, when I connect the power wire to the headlight assembly, both front parkers turn on, even though the lights are not turned on. When I get some time, I will be cleaning all the terminals, but was wondering if anyone might be able to enlighten me as to what is causing this problem. Thanks
