starting problems i just pulled motor and box outa my vr ute
macca69
macca
South east Queensland
Vr ute
it was running fine just oil leaks ..starting problems i just pulled motor and box outa my vr ute replaced all seals and gaskets in motor and gear box ( dint do head gagskets) replaced harmonic ballancer $135 from auto barn and crank angle sensor $45 auto barn , the old ones worked ok just did them while it all out all so replaced throttle body seals to and All hoses water pump $44 auto barn every thing was ok before pulled it out put it back in we have triple cheacked every thing stil woint start us aero srt it tries to then nuffing is getting fuel and spark
maginoodle
vy series2 ss crewman
is it getting injector pulse? if you are getting fuel and spark it sounds like injectors arent pulsing. Did you put the fuel hoses on the cprrect way? I have accidently put them on the wrong pipe before.
