jeepster
I have VS series 2, and when I open driver's door, the speaker goes dead. Also sometimes in
hot weather, it drops dead. I removed door trim and can't see a problem with speaker wires.
I also looked at wires coming out of radio, and nothing is stretched tight. Then I wriggled the
loom between the door and A pillar, the speaker goes off and on, so there is an intermittent
fault in there. The mirrors and power windows always work. Now the problem is that the left-hand
door has started doing the same thing! Is this a common fault with VS ?
