pungent
- Aug 3, 2008
- 57
- 0
- 6
- VR 5.0L
A quick run down as to where i'm at now and what has been done.
It's a VR V8 and have converted to a VS Auto box.
We changed to VS wiring harness and computer that was in the car with the box and also ran the same tune in the ecu.
Basically everything that was in the VS to run the engine and box is now in the VR.
Now where it starts to get confusing.
The VR was running with VR auto V8 ecu and harness and always had the engine light on but the car had been converted to manual so we had just put down that the engine light was due to not having the auto in it (this is not my car by the way) and error codes were never checked.
Now we have the engine light on and is in limp mode and we have errors
Code 66 - 3 - 2 Shift Control Solenoid Circuit Fault - Auto Transmission Only
Code 67 - TCC ON - OFF Solenoid Control Fault - Auto Transmission Only
Code 81 - 2 - 3 Shift Control Solenoid 'B' Fault - Auto Transmission Only
Code 82 - 1 - 2 Shift Control Solenoid 'A' Fault - Auto Transmission Only
Now what I have done is found the wires that come out of the ecu that control these particular parts of the gearbox and by the wiring diagram it say's they should all have 12 volts with ignition on.
I get zero volts at all these wires with ignition on straight from the ecu.
All earths etc are connected and fine.
We have checked all fuses and all the power wires into the ecu as well as all other wires associated with the gear box and everything reads ok.
Is there something simple we have missed or what else could be wrong.
If there was something wrong inside the box then the ecu would still have power going out to the gear box so I don't see any reason at moment to pull pan of box if the power isn't getting to it to start with.
Any help or idea's would be appreciated.
PS. We have tried another ecu and had the same result, also loaded a couple of different tunes into the memcal and still had the same issue and same error codes.
