trying to wire in some extra driving lamps so when i put the headlights on they will turn on as well- (not as a separate switch) just wondering if someone could tell me where i could place the positive wire from the driving lamps so i can connect it directly to a wire running from the headlights somewhere?
I would suggest you wire it up the same as the factory foglamps that come on the SS commodores.
Get your hands on a gregories manual. and use a relay, fuse, etc. If youre clever enough, you can wire it into the factory fuse box. (Unless your loom comes with the wiring already there, in which case, you just need the relay and fuse to plug into the empty spots.)
Then you can have the driving lights on or off using the extra switch (under the h/light switch) ... but ... they will only work if the headlights are on.
They will then work as follows:
Foglight switch ON + Headlight Switch OFF = driving lights OFF
Foglight switch ON + Headlight Switch ON = driving lights ON
Foglight switch OFF + Headlight Switch OFF = driving lights OFF
Foglight switch OFF + Headlight Switch ON = driving lights OFF
