Results 1 to 4 of 4
Thread: High Beam lights glowing when on low beam ?
    Madhouse_Dave's Avatar
    Madhouse_Dave is offline Crazy but Happy
    Vt Berlina Sedan & VT Excutive Wagon
    May 2005
    Cool High Beam lights glowing when on low beam ?
    Hi All
    I have a problem I was wondering if anyone else has come accross.
    I noticed when the car lights are on low beam that the high beam glows very red not lighting up to a full strength light. I was thinking its an earth problem
    but I cant find anything wrong with the earths. :b: one of those things that makes you pull your hair out. when I turn on the spot lights I installed they arent on on low beam. when I flick up to high beam the spots work fine. when i flick back down to low beam the sopts stay on the relay doesnt drop out. any Idea ? Please ? I know an Auto Electrician
    I've Got Papers To Prove I'm Sane.
    Can You Produce Some Too ???
    Madhouse_Dave
    Tasmaniak's Avatar
    Tasmaniak is offline Not a valid input....
    car
    Apr 2005
    Sounds like there is a very high resistant joint in there somewhere that is leaking into the high beam circuit. Obviously enough to hold the relay closed.
    May 2005
    Cool
    I will check it out tomorrow and see what I can find.
    Thanks for the Input.
    Madhouse_Dave
    Tasmaniak's Avatar
    car
    Apr 2005
    No probs and good luck.
  1. High Beam on VK SL
    By booma11 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 19-10-2006, 01:19 PM
  2. high beam on and off
    By abehrendorff in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-02-2006, 06:05 PM
  3. high beam....
    By stock_vl in forum Electrical Wiring / Questions
    Last Post: 12-05-2005, 11:03 PM
  4. VT High Beam
    By budge in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-03-2005, 04:39 PM
  5. no low/high beam
    By gambit120 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-11-2004, 02:06 PM
