tyrefryer
- Oct 18, 2005
- 331
- 2
- 18
- Age
- 36
- Location
- Perth
- Commodores!
Hi, i was connecting an led strip in place of the boot light and it wasnt lighting up bright as it should.
Bought a new one, same thing.
Tested wires with a multimeter and it gives 8V between the two wires but 12V between positive and a ground source so im guessing the ground wire is somehow at 4 or so volts.
I think this is a common problem cos with almost all the commodores iv owned the boot light didnt work and when i go to pull it out to look it touches the bare metal on the way out and comes on.
I tried solving this problem by earthing it somewhere else but the boot light switch must be on the -ve wire.
Is there any reason this happens and any way around it or to fix it?
