slimecity
- Sep 15, 2006
- 29
- 1
- 0
- Location
- Christchurch NZ
- VS Ecotec v6 (Mk 2) 1996 Auto
Hi there - I have a VN 1989 V6 and live in NZ. These commys were made in Aus (I think) and didnt include an O2 sensor (definitely).
The problem is that I had a CEL and before I knew how to retrieve the error code took it to the mechanic (stupid move) who promptly replaced the CPU - needless to say this didnt fix the prob and I am now getting an "engine running lean" code 44.
I think the original code may have related to a faulty coil pack - i replaced that myself and my theory is that this fixed the original fault (intermittent stalling).
My question is: As they have replaced the CPU, does it make a diff if they installed a CPU meant for ozzy models - and now the new CPU is interpreting no signal from any O2 sensor as an "error?"
I dont have an O2 sensor, just a nut screwed into the exhaust mani where the sensor woud normally be. There is a thin green wire hanging close to the exhaust mani which I think would normally connect to the O2 sensor.
I want to be sure this isnt likely to be causing an issue before i start checking out other fuel flow/injector/FPR possible issues.
cheers! Simon
cheers! Simon
