pretty basic wiring question
fonzo
vs berlina s2
I have a washer bottle i want to wireup. but i need it on a toggle switch and it has nothing to do with the original washer bottle so it cant be hooked up threw that. wheres the best place to get the 12v feed from?
keeny
keeny
Maitland, NSW
BAGGED 04 VY SS S2 HBD MANUAL UTE
whats it going to be doing and where will it sit?
nstone63
wants a new car
Roxby Downs SA
1988 VN Executive
squirting something in the vicinity of the back tyres?
fonzo
vs berlina s2
nah nah lol. dont need liquid horsepower hahaha. its a radiator/air con condensor/intercooler spray kit thing i got at a garage sale for 11 bucks lol
fonzo
vs berlina s2
towing a tandems around ayres rock ahha
PanthaVS
VS S-Pack SII
Directly to the battery on its own "inline" fuse... although... considering it is "essentially" the same as the waher bottle in your car... why dont you tap into the supply power to the washer bottle...
then, it will be fused via the fuse for that.???
fonzo
vs berlina s2
But if i tap into that line will it only work when i pull the washer stalk foward?
ephect
Donating Member
VS Acclaim V6
nope it will only use the same fuse as the washer, if you use the same power feed, you can install a switch where ever you want in the cabin and feed it down to the mister
PRAVX II S
Australia
Commodore
Make sure the switch you get or got can handle the current draw from the washer unit. Other wise it will burn out.
You can use a relay if the switch cant handle the current. Using a relay is better because you can use a smaller switch.
