VZ No power to cigarette lighter socket
davevz
sydney
05 VZ SV6
G'day,
I have lost power to my cigarette lighter socket. Fuse is ok and been checked, there is 12v at the fuse socket, but nothing at the cig lighter socket or the plug which connects it under the console. I know of someone with a VZ berlina with a similar fault. Is this is a common fault?? Does anyone have a wiring diagram with the cigarette lighter circuit??
p.s. I have also lost illumination behind the dimmer section of the headlight switch.
Thanks, Dave.
steve44
Sunshine coast
VY
G'day,
Thanks, Dave.
I have the same prob, does anyone know how to fix?
Andy
Donating Member
Muswellbrook NSW
VS Commodore Ute
Possible you have a fault between the Fuse Box and the actual port itself. Do you have a 2nd port somewhere in the car (One reserved for stuff like a fridge and the likes)? Most common place for one of
