The VR has a 4 wire oxygen sensor. Where does the red wire connect at the opposite end of that loom....it has a female spade connector.
Also there are 2 wires that run inside the car, at the computer loom connection. One is yellow, and the other is white with a red trace.
I think the yellow wire address is C12 on the computer plug, and the white/red address is B11.
To what do these wires connect to on the normal VR dash?
