Results 1 to 3 of 3
Thread: Dash Light Warning Light
    95 VS 5ltr Statesman D/Fuel
    May 2005
    Exclamation Dash Light Warning Light
    My warning light for a busted globe comes on whenever I turn on my parkers and lights it does the flash thing then stays on always triple checked all globes, fuses, relays, everthing that I can think of getting very frustrated :b: :b: has happened since I got the car
    PLEASE HELP
    VR Berlina V6
    Sep 2005
    orange
    Just a stab in the dark but does it have a towbar? if so check the plug for water or corrosion, also check where the wiring is spliced into your original wiring as they use those b#$%@ard scotch locks (little plastic things that joint a wire to an exsisting wire by cutting all but a few of the wire strands). They will let volts go thru so they may still be tested with a multimeter but a test light wont light up because it needs more amps to run.
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    Since its a Calais, if ANY globe is out, the light will stay on. Check the floor lights, open door lights, glove box lights, and where theres a globe, even the boot might be the problem. Other than that, i have no clue. or just take the warning globe out
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
  1. Dash warning light (!) I beleive it's brakes?
    By MBS206 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-12-2011, 12:33 PM
  2. Dash warning light probs....
    By NOGEN 3 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 30-10-2006, 04:08 PM
  3. Tail light warning light
    By G4orce in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-08-2006, 06:27 PM
  4. 'Rear light bulb failure' warning light
    By Misaprop in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-04-2006, 03:07 PM
  5. VZ dash fog light warning light
    By Torquative in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 14-08-2005, 07:13 PM
