Results 1 to 5 of 5
Thread: VS-Battery keeps going flat
    evanthe mac Guest
    Default VS-Battery keeps going flat
    I have a problem with my VS Esteem. The battery goes flat overnight. I leave it with the battery fully charged and 12 hors later it's as flat as a tack. I thought it was a dud battery so I put a new one in and it hasn't helped. I can't see any obvious short or anything else that might drain the battery. The car is stock standard. Any ideas. Cheers Evan. :b:
    VP Exec
    Jun 2005
    My guess would be the boot light staying on.
    If not and you have access to an ammeter, (a suitable multimeter is about $10 at Dick Smith/Jaycar so you prob. should), disconnect the battery earth, connect the ammeter between the wiring harness earth terminal and battery terminal and take a current reading. Shouldn't be more than about 0.15A with everything switched off. If it is more, start pulling fuses (under dash and under bonnet) until the reading drops, which will tell you which circuit to to look at.
    evanthe mac Guest
    Cheers Cheap 6, it was too easy, I checked and the light WAS staying on the boot. Brilliant. My car fixed. Thanks heaps.
    2007 VE SV6 3.6 Auto
    Sep 2005
    Default Common issue with VS
    Had the same problem myself, even bought a new battery, which promptly went dead two weeks later.
    Took it to an auto electrician, and he showed me a quick test.
    Holden were so thoughtful to install a boot light check hatch (fold down back seat ).
    He said on the VS it was a reasonably common issue.
    Regards
    Bob
    EVL253's Avatar
    EVL253 is offline i hate cops!
    cranky black VB SLE
    Mar 2004
    yeah my vs had this problem as well.bent the tab back out for the light switch and it turns off now.stupid flimsy metal holden used to mount the switch on
    So some people are complaining about my motto on cops.well if u knew what ive been thru u wouldnt.so quit your whinging!
    i hate cops!
  1. Totally Flat Battery, Cant get into car
    By Everton in forum VY Holden Commodore (2002 - 2004)
    Last Post: 08-05-2007, 08:20 PM
  2. VN battery going flat whats going on?
    By Gazza2005au in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-06-2006, 10:59 PM
  3. VQ Battery Going Flat
    By VQ Stato in forum Electrical Wiring / Questions
    Last Post: 11-07-2005, 04:29 PM
  4. Vr flat battery, overheating help
    By audiosoup in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-06-2005, 05:11 AM
  5. Flat Battery
    By Randy18 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-03-2005, 12:38 PM
