Ive been after the exact same thing ...pmed plenty of people and got nothing back...looks like its the 64 dollar question that no one can answer or cant be bothered answering me back.
From what I have seen you need to cut out the bit for the light and then some slots for the nibs to go through and the 12 (6 each side)clips secure it to the bar ...you have to buy them separate as they dont come with the bezel.You also need to buy the captured nuts that go to mount the light.
I thought about buying a rooted bar from a wreck and do a dummy run to get a idea of how to do it before I tackle cutting my good one.
You also need to drill 2 holes in the reo bar to mount the light itself.
Here's a picture I found of the bar with the hole cut out for the bezels.
http://forums.justcommodores.com.au/...achmentid=5829
And here is what the light looks like from the back showing the clips that hold the bezel in and the mounting of the fog light on the bar itself that I took from a car in a car yard with them fitted and also the wiring for the switch.
LinkBack URL
About LinkBacks
This is my vr that I rebuilt ....
......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
