Results 1 to 12 of 12
Thread: ecotec engine swap / wiring.
    VS Bt1
    Mar 2011
    brisbane
    Angry ecotec engine swap / wiring.
    hey i put the V6 motor from my 96 VS bt1 into a datsun 200b just cant get the motor to do anything, when you go to start it all you get is a click noise from one of the relays.
    had a mate help remove the engine and thin some wires just wondering what can be taken out or what has to be there for the motor to run incase something has been removed that shouldnt be.
    im using the vs key and ignition barrel set up but is there any other security features?
    car ran fine before the motor was removed.
    VL 308 calais wagon, VR Ute
    Mar 2011
    Boyanup
    Will need the Body control module, they control many things electric in the car, and are coded to the key, ie change key heads need to change BCM's or get the security feature removed. The BCM is located on the drivers side under dash near fuesbox, will have 3 plugs comming out of it. currently doing an ecotech conversion on a vr ute, so found this out recently.
    s/charged v6 HR Holden, s/charged v6 EH Holden,
    Sep 2007
    Could be any one of a hundred things buddy. did you use the full VS under bonnet fuse/relay box & ecu & wiring harness as a few of the signals from relays/ecu are interconnected.
    VT Calais S1, VK Wagon EFI 5.0L
    Jul 2005
    VS Bt1
    Mar 2011
    brisbane
    yeah im using the full wiring harness ECU and BCM are attached using the Vs fuse and relay box. the fuel pump isnt goin off either. starter motor works but only when hooked up directly to the battery.
    Sep 2007
    R U Using the same ECU/BCM/Key/Key holder/Engine from the same vehicle , ALL have to match.. ????
    VS Bt1
    Mar 2011
    brisbane
    yeah everything is off the same car it all matches. My mate bridged the starter relay and had the motor turnin over. But thats the only and the fuel pump doesnt go off either. Heard you can solder the key head to the bcm. Any one have any info on how to do it?
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    P/N Inhibitor switch correctly installed?
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    weston is offline Holden VH V6 Commodore
    VH Commodore
    Apr 2009
    Not sure if the VS has the same set up electrically to the VN but my VH i put the V6 into wouldnt fire, it would only crank over found out to be a dodgy plug next to the fuse box under the hood that ha d the computer wire in it.
    Has yours got a conector that sits in the VS passenger side dash just above the computer that joins to the dash loom from the engine loom this can stop the car starting correctly.
    *uwishn* is offline Holden special vehicles
    vl walkinshaw(replica) vt clubsport r8
    Jul 2010
    sydney
    Vt Berlina S Pac SII L67 Turbo Project
    Jul 2010
    I think the security feature would actually get the starter motor going but wont start
    would be the smartest thing to get it turned off
    so basicly your saying it sounds like when the battery is loose it just makes a tick and stops
    get the multimeter out and work from there
    vl
    Apr 2011
    brisbane
    hey mate, if you need a hand pm me, im a mobile sparkie. sounds pretty hard to help via email, sounds like a wiring problem.
  1. engine swap from vs ecotec to vr s/wagon(non ecotec)
    By gumby05 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-05-2010, 06:33 PM
  2. [LS1] swap from ecotec to ls1
    By psivyv6 in forum LSx Development and Modification
    Last Post: 17-03-2010, 10:11 AM
  3. ecotec to ls1 swap, what problems will i have?
    By fluxxx in forum General Discussion
    Last Post: 04-05-2007, 01:21 PM
  4. N/a to S/c ecotec engine swap
    By DaBakes in forum V6 Development And Modification
    Last Post: 15-04-2007, 08:22 AM
  5. ECOTEC: Whats the diff between VS S1 & VS S11 & VT V6??? Engine swap
    By holden#1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-01-2006, 07:45 PM
Tags for this Thread
