Results 1 to 4 of 4
Thread: Indicators not working! VX Berlina plz help!!!
    VX Berlina SI V6 3.8L
    Mar 2011
    Exclamation Indicators not working! VX Berlina plz help!!!
    Hey guys, I just finished repainting my dash and realised when I reassembled the cluster the speedo did not work, so I re-did that and then one of the little screens didn't work. So I re-did that again and now I have it all reconnected, it seemed fine but then I realised that my indicator lights are not working at all! lights work but not indicators.
    Plz help me, Is there a wire in the harness I need to check? If there is could anyone tell me or send me to a diagram off all the wires in the dial harness??
    Serioulsy I really need the help as without indicators the car is unroadworthy!
    southaussie's Avatar
    southaussie is offline Family Guy
    VT Executive 97
    Mar 2011
    Tranmere, SA
    this happened to me !!! when you turn on indi's do the blow the fuse ? if or if not check your hazard light button pins .. mind tilted slightly and arched out when i put the indi's on but hazards worked ! so ...
    removed hazard button
    remove plug
    look in back of button
    check the pins
    when you connect plugs back in turn plug most pins at top and jiggle it in.
    if there is any resistance dont push
    Attached Thumbnails Attached Thumbnails Indicators not working! VX Berlina plz help!!!-info-hazard.jpg
    Mar 2011
    yeah i checked the hazard lights and they work! i was worried that i stuffed something in the dials wen taking that apart but the lights, dials (and indicator lights on the dials cluster) and the clicker all worked. So it wasnt a blown fuse. so I assumed I need a new stick but when I reassembled everything and came back to it 15 mins later it all works! Lol I think it was either a one off or attatching the hazard light button helped
    VT Executive 97
    Mar 2011
    Tranmere, SA
    Quote Originally Posted by Gabster118 View Post
    yeah nothing works for indi's if hazard switch isnt plugged in !!
  1. Indicators aren't working!!!!
    By barney86 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 24-04-2010, 06:03 PM
  2. Vk indicators not Working
    By chinabone2000 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 21-04-2010, 07:02 PM
  3. Help! Indicators not working!
    By LittleMissVE in forum Electrical Wiring / Questions
    Last Post: 05-04-2010, 11:57 PM
  4. HELP!! indicators not working
    By 17UCK! in forum Electrical Wiring / Questions
    Last Post: 13-10-2009, 07:25 PM
  5. Indicators Not Working?!
    By 1991_Vn2nV in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-04-2007, 06:07 PM
Tags for this Thread
