Results 1 to 11 of 11
Thread: speedo won't work
    vr executive
    May 2011
    ravenswood
    Default speedo won't work
    i pulled the dash out of my 1993 vr executive to change the globes and on putting it back in tthere the speedo hasn't worked or the odometer all other gauges work fine is this an expensive thing to fix and does anyone have any ideas
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    2 things to check - the copper tracks on the back of the cluster can be broken or the speedo ribbon connector is no in all the way or broken.
    The copper track can be fixed some times with silver foil and tape/glue.
    I doubt the speed sensor died at the same time as you pulled the cluster out.
    and 3 Dangerous non ABS VN's
    vr executive
    May 2011
    ravenswood
    thanks heaps for that i will pull it out again and have a look hopefully i don't bugger anything in the process lol
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by benny the vr View Post
    The backing often snaps close to or around where the 3 dash plugs go in.
    vr executive
    May 2011
    ravenswood
    88GreenVN's Avatar
    Jun 2006
    is it easy to notice or do i need to know what i'm looking for
    Most of the time the main plastic backing will be cracked and there for snapping the copper track. If it is broken you can try to fix it by scratching a little of the green coating off and take on some silver foil so that it makes contact again. if this gets it working then you can look at replacing the PCB backing with a good one or replace the cluster.
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    Quote Originally Posted by 88GreenVN View Post
    have u tried those PCB track pens rather than using foil? not sure how well/long these last tho, i bought 1 2 try fix my rear window demisters tracks which worked but then didnt after my rear window got tinted, i think their cleaning solution took it off but i didnt worry as i ended up gettin a new rear window neways so didnt get 2 see how well/long it lasts.
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by wrx884 View Post
    No I havn't - not seen one. Foil and sticky tape works well
    In fact I have a VN L3 to repair. Last one I did with thin wire. This time foil and tape
    wrx884's Avatar
    Mar 2006
    this is it, try it n let us know how it goes.
    Jaycar Electronics - Search results conductive pen
    not quite as cheap as foil and tape hahaha
    2003 VY II S-Pack 25th Anniversary
    Feb 2010
    Central Victoria
    ive get some of those PCB pens for when i try and volt mod some computer circuit boards, they work pretty well .. i would recommend them if you got the money to cough up as wrx said lol.. but the foil is alot cheaper and will probably do the trick!
    88GreenVN's Avatar
    Jun 2006
    I also have about 30 L2 PCB's in a box. I've killed alot of VR and VS L2 clusters over the past 3 years to upgrade VN/VP clusters. just cant bring my self to toss em out - figure 1 day people may want them lol.
  1. Speedo/alert won't work - replaced cluster, still won't work
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-05-2011, 10:33 AM
  2. Speedo/alert won't work - replaced cluster, still won't work
    By VS Omega in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-02-2009, 06:54 PM
  3. Speedo won't work
    Last Post: 26-01-2009, 07:59 PM
  4. Will A VR V6 speedo work on VR V8
    By VrWagz1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-01-2009, 11:20 PM
  5. VP Speedo doesnt work then works!!
    By bladerunnerkim in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-03-2007, 12:48 AM
