Results 1 to 5 of 5
Thread: VT Battery Draining, Relays on
    vp wagon executive
    Apr 2008
    Default VT Battery Draining, Relays on
    Hi, i have a battery totally draining overnight in my 2000 VT.
    I heard a relay clicking as i reconnected the -VE battery lead, turned out to be the Internal Illumination relay on the underdash fusebox. I pulled that out and found out there is ANOTHER relay latching in the BCM. NO interior lights are on (faulty switches) so i am open to ideas of what to look for. I have looked at roof light, glove box, boot. anything else to look for? I also noticed the thermo fans would sometimes come on when i started the car but the aircon was off (i have since learned they have sticky relays) it also would not start at one stage (totally no sign of turning over) but battery was fine. since pulling all relays/fuses things seem better than they were but this Int Ill relay is still getting power for some reason.
    Hope someone can suggest a troubleshooting procedure.
    Thanks
    Gary
    vx custom 600RR
    Oct 2010
    the second click you hear is for the power windows
    chances are that the alternator is faulty or the battery needs replacing
    on the vt/vx all power is switched off to everything inside the cabin after 45 mins after the car has been locked, unless you've added something and wired it to the battery
    vp wagon executive
    Apr 2008
    Well i removed all fuses and relays from the fusebox and it still clicks when you reconnect the negative batt terminal, i ran two wires (onefrom negative battery lead, other from negative battery post) to the drivers seat to act as a switch, as i connected/disconnected the wires i felt under the dash behind the fuse box and there is a relay clicking in the BCM, hope that clears things up a bit more.
    Gary
    vp wagon executive
    Apr 2008
    Well i don't think it's the BCM doing this, can someone please tell me if i'm missing a light or something to check? i pulled the INT ILLUM relay out for a week and battery is fine. just gotta find out what is connected to that relay apart from the previous lamps mentioned. Any help appreciated.
    308 vb 5speed
    Jan 2012
    hello our vt v6 has the same problem It is at the auto elecs now,they dont know why the interior lamp relay is getting power when its not supposed to !!!!!!What was the problem with yours in the end?
    Regards Peter
  1. VP Battery Draining
    By VP_Commodore in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-05-2011, 05:18 PM
  2. sub draining battery
    By jayvt in forum Car Audio
    Last Post: 07-05-2011, 09:07 AM
  3. draining battery
    By whitey08 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-01-2008, 01:37 PM
  4. Battery draining!!!
    By Pure Evil in forum Electrical Wiring / Questions
    Last Post: 28-09-2007, 01:02 PM
  5. battery draining.........
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-08-2005, 03:15 PM
