Results 1 to 5 of 5
Thread: Trouble with electric oil pressure gauge
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Default Trouble with electric oil pressure gauge
    I just fitted a Calibre oil pressure gauge and am not getting a reading, when engine starts the needle shoots up to 20 PSI, then straight back down to zero and stays there. I have spent hours mucking around with different earth points on the engine and on the chassis, but either way, there's no reading.
    Any ideas? Faulty gauge/sender?
    wamboin23's Avatar
    wamboin23 is offline Donating Member w/ Boost
    VS Calais - Cooled L67 + T56 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    does it go all the way to full pressure when the key is on, the go back down once the engine starts? if yes, sounds like the sender unit you have is actually a switch.
    did you fit the sender that came with the gauge or did you just tap into what is already there? because the stock one is just a switch.
    VYMAD's Avatar
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    I fitted the sender that came with the gauge.
    The needle only goes up to twenty PSI, on a 140 PSI gauge for a second, then back to zero.
    VYMAD's Avatar
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    OK, me so happy! I took the gauge and sender back to the shop, swapped for another set and hey presto, all working.
    96 VS executive series II 'S pack'
    Jan 2011
    australia
    hey you wouldnt happen to be able to post a pic of your diagram or briefly tell me where which wires go were? i got the crappiest diagram that is for an air/fuel anyway....
  1. [VIC] Auto meter electric oil pressure gauge
    By chargedvx6 in forum Parts And Other Items For Sale
    Last Post: 16-12-2009, 01:45 PM
  2. VZ Sedan Electric Aerial Trouble
    By Insanity in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 24-09-2008, 02:41 PM
  3. HELP oil pressure gauge ?
    By Lazin in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-05-2006, 01:02 PM
  4. oil pressure gauge, oil pressure
    By VN-88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-10-2005, 09:31 PM
  5. Oil Pressure Gauge
    By jetpilot83 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 05-09-2005, 04:42 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
