Where do you wire a voltage gauge?
VYMAD
SILVERFOX
BUNDABERG Q
VY EXECUTIVE S2
Where do you take the volt feed from on a VY Ecotec?
Not sure if I'm going to install one, as they are fairly pointless IMO, but was wondering where it gets wired to?
m1lky
Auckland
VY SS
Preferably directly to the battery.
In reality you can wire it to any positive wire. The additional losses by not being directly to the battery are less than the inaccuracies of a normal gauge
VYMAD
SILVERFOX
BUNDABERG Q
VY EXECUTIVE S2
Fair dinkum, to the battery? Thanks for the quick reply, I thought it would be to an alternator wire.
m1lky
Auckland
VY SS
Alternator is connected to the battery anyway. Just steal the feed off the headdeck or cigarette lighter and you away laughing.
For reference provided your thinking of the same sort of gauge i am
http://www.grandamgt.com/voltage.html
VYMAD
SILVERFOX
BUNDABERG Q
VY EXECUTIVE S2
Thanks, yeah that link is helpful. So any 12 volt accessory/ignition source, eh.
Cheers.
m1lky
Auckland
VY SS
Pretty much. Unless you have some uber accurate gauge then go to the battery
VYMAD
SILVERFOX
BUNDABERG Q
VY EXECUTIVE S2
No, it would just be a cheap Calibre gauge like the oil pressure one I've just fitted. So I will just connect it to accessories curcuit if I do decide to get one. Cheers.
mint
55
n
VE
They are only pointless until you start having problems with your charging/electric system (which in a VY can't be far away). Then they're handy.
m1lky
Auckland
VY SS
Or to keep an eye on the battery if your cranking the sounds with the car off
Chrisvyss
02 VY SS
