chevsrus
- Nov 24, 2008
- 4
- 0
- 0
- Location
- NSW
- 1941 chev, 1937 chev truck, 1931 chev coupe, vs 3
Help!
i have a series 3 1999 statesman 5.0 with a tartarini lpg processor
It wont start on fuel because the system requires fuel initially to run.
i have no power to the pump
I have replaced the pump and even taken the processor and loom out of the car
but still no power, checked replaced the fuses and relays.
the loom that powers the pump and sender has 4 wires but none of them are purple as i was told that its the positive supply.
I am not too sure but was told that when they install the lpg they cut one of the wires to the pump and run it through the lpg but as i have removed all wires from it they were not cut but only spliced into the pcm harness.
Can i supply the pump directly to get it running and what colour wire is it near the pump.
I can then take it to a auto elec to fix it properly.
Any ideas or diagrams for a tartarini processor as i cant find any info.
thanks
thanks
