+ Reply to Thread
Results 1 to 4 of 4
Thread: Wiring connector for mobile car kit!!!
    patmoss1976 Guest
    Question Wiring connector for mobile car kit!!!
    Guys,
    I own a 2005 SV6 VZ and have bought a nokia ck-7w car kit.
    Can anyone tell me exactly how to access the 6 pin connector and what colours are for what on the connector?
    Do i need to buy any additional connectors to allow me to hook into it?
    cheers fellas
    Patmoss
    Tasmaniak's Avatar
    Tasmaniak is offline Not a valid input.... Tasmaniak Executive Tasmaniak Executive Tasmaniak Executive Tasmaniak Executive
    car
    Apr 2005
    Remove the glovebox by bending the rubber tabs on the side, this will drop it down, then pull it out of it's hinges. On the right hand side, you will see two screw holding the fascia along the transmission tunnel in place. remove then and pull the fascia out of your way.
    There will be a big black wiring loom wrapped in clothe, taped onto the side of it is a white 6pin plug.....thats the one you are after.
    The orange wire is your constant power.
    The yellow wire is Accessorys
    The black wire is earth (use it and do not create your own earth)
    Yellow with a Black stripe is the Radio Mute wire.
    The two blue wires are for your speakers. Cut the the speaker wires and hook them upto there. I like too use them AND the original speaker wires, as the radio will not alert you when a SMS comes through.
    Hope this helps~!
    08 VE SSV M6
    Dec 2005
    When cutting the the car kit speaker off, how do you know which one is meant to go to the speaker + and speaker - on the VZ car plug?
    Tasmaniak's Avatar
    car
    Apr 2005
    it doesn't really matter. But if you want to get pedantic then your negative speaker wire can goto the blue wire with a black trace. But ultimately....it makes bugger all difference.
+ Reply to Thread
  1. WH Statesmanmobile phone wiring connector.
    By nigels in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-11-2007, 09:23 PM
  2. wiring for mobile phone
    By dazza123 in forum Electrical Wiring / Questions
    Last Post: 28-10-2007, 07:23 PM
  3. VE Mobile Phone kit wiring
    By Plastic in forum Electrical Wiring / Questions
    Last Post: 03-03-2007, 09:22 AM
  4. Mobile phone connector as Audio Input
    By rowen in forum VY Holden Commodore (2002 - 2004)
    Last Post: 22-08-2005, 02:27 PM
  5. Mobile Phone Connector Details
    By Rippa in forum VY Holden Commodore (2002 - 2004)
    Last Post: 11-06-2005, 09:14 AM
