Results 1 to 2 of 2
Thread: VN/VP V8 Cruise into VK with Injected 5L
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Default VN/VP V8 Cruise into VK with Injected 5L
    Hi,
    I am planning on fitting cruise of of a VP Calais to my VK, works way better than the original VK setup. I have been reading Volume 7 of the VN Service manual
    Dash switches wont be a problem, They are positive switched
    Mounting it and connecting it up wont be a problem
    Brake & clutch pedal switches wont be a problem I might connect up a 5th gear switch via a vacume switch so when in 5th gear and Zero vacume occurs cruise will switch off to protect 5th gear down the track.
    Questions :-
    Problem I have is the speedo sensor
    I understand the factory ECU receives a signal from the gearbox speed sensor via the dash cluster, so my ECU received the correct signal I used a a modified sensor that has the divide by 5 circuit built into it.
    Question - Does the Cruise control module receive a signal direct from the gearbox speed sensor or a modified signal from the dash cluster? Before I start connecting it all up and fitting it I want to make sure I cover all my problems before they arise
    Next
    Looking at the circuit diagrams for the cruise control there is a resistor between the poles of the output side of the on/off switch to the set & resume switches
    Question - Anyone know the value?
    cheers
    Scott
    GothicKidd's Avatar
    GothicKidd is offline ლ(ಠ益ಠლ
    Series II VR Commodore
    Dec 2010
    South Australia
    I'm not exactly sure, but I do believe the resistor in my Indicator stalk for the cruise control is 470Ω 5% for the resistor value..
  1. vk fuel injected 202 convert into a 5.0 fuel injected all what i need to do
    By dazz9 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 08-09-2010, 11:25 AM
  2. Replies: 3
    Last Post: 04-09-2010, 07:27 PM
  3. Injected VH SLE
    By starkie85 in forum VB - VC - VH - VK
    Last Post: 02-10-2005, 10:52 PM
  4. Injected 5L into VK
    By blandyVK in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 08-06-2005, 10:42 AM
