Results 1 to 6 of 6
Thread: VY SS Ute Ignition power feed ?
    sixes's Avatar
    sixes is offline UTEPILOT
    VY SS II M6 Ute
    May 2004
    Townsville QLD
    Default VY SS Ute Ignition power feed ?
    Anyone know of an easy spot to get +12v from the ignition feed?
    TIA
    Styled by Holden, Powered by Chev
    VY Clubsport R8
    Sep 2010
    Cigarette lighter, alternatively you can grab a circuit tester and check for any yellow wires which are mainly power and tap into there. Just make sure you turn your ignition on so you know it goes on and off with ignition.
    sixes's Avatar
    VY SS II M6 Ute
    May 2004
    Townsville QLD
    Cigarette lighter is accessory feed. Need to find and easy spot that I can get power from the ignition. Just wondering if anyone knows an easy spot to tap into
    one_and_only2004's Avatar
    one_and_only2004 is offline Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    The power feed for the interior fans? Fuel pump circuit?
    Those are two I can think of, the AC would probably be the easiest.
    VZ Thunder - 360RWKW Turbocharged V8 - Parts by AKO Performance Tuned by BPS
    VY SS
    Jun 2006
    Albany
    directly off the ignition barrel would be the easiest although the wire is quite thick and might be a bit hard for you to splice into if you haven't done it before, what do you need the ignition feed for?
    sixes's Avatar
    VY SS II M6 Ute
    May 2004
    Townsville QLD
    I only need it to run the Wideband Oxy sensor gauges so about 3 amps at the most. Would rather have them work when the ignition is on and not the accessory (current set up)
    I use the WBO2 for tuning and logging data
  1. power to ignition key
    By ab56452001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-12-2011, 12:49 PM
  2. ignition power
    By rousey in forum General
    Last Post: 14-03-2010, 11:41 PM
  3. Need some feed back...
    By black as in forum General
    Last Post: 20-01-2010, 10:55 AM
  4. RSS Feed
    By tommo82 in forum The Pub
    Last Post: 16-03-2009, 08:43 PM
  5. ignition source power under bonnet?
    By jamo25 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-12-2005, 06:22 PM
