I bought a 2001 VT wagon 2nd hand off a dealer. I have had a string of issues which are being worked out. But one issue I can't figure out. Indicators work fine. Hazards don't. Now I'm not sure but when I lock and the car by remote the hazards don't flash, should they?
What could the problem be? I just need some direction before I rip the dash out and break things I don't need to break.
Oh, and my heater control. Cold is cold 3 clicks clockwise it's Sahara Mid-Summer. What up with that?
The hazard flasher is probably a separate unit to the indicators. Try cleaning & replugging it, then maybe replacing it.
Heater? Most common problem is that it doesn't work?!?
no the hazard and indicators are the same unit, if your hazard light wiring etc is ####ed, your indicators wont work.
have you looked at the fuse? under the steering wheel to see if its blown?
Starin at the world through my rearview
Go on baby scream to God, he can't hear you
I can feel your heart beatin fast cause it's time to die
Gettin high, watchin time fly
there are 2 fuses for hazards and indicators, so make sure the hazard fuse isnt blown.
heater problem could be a faulty heater tap under the bonnet
Sweet, I'll check out the fuse tomorrow. I checked the fuses under the bonnet, but hey who knew there was a fuse under the steering wheel. Not me.
I'll inspect the heater tap, after Googling what a heater tap is.
Ok. direct under the steering wheel there is "the thing that looks like it could take a fuse" but there are no fuses in it. I tried the small blade fuses (10amp), no dice, it's too big. What kind of fuse should it be?
i hope your not talking about the diagnostic plug lol, you have to pull the large panel under the steering wheel down, then inside you will see all the fuses
CAR: VT Commodore Sedan audio car - SOURCE: 7" double DIN DVD/GPS - AMP: Pioneer monoblock / Pioneer 4 ch. - SUB: Kenwood DB+ 12" in 22lt slot ported box - REARS: Kicker RS60.2 splits - FRONTS: Kenwood KFC-S702P splits - MISC: Custom fiberglass iPhone4 dock moulded in center console, White / red LED cluster and dash lighting, SAAS Vortex drivers seat
