well i did a motor swap in my v6 vs stato and now it wont turn over and i found these loose plug and im not sure where they go
any rely wanna try and get this thing turning over today
The one near the battery is what throws power to the starter in some way, and the other one will only go as far as it reaches so id be looking under the intake or somewhere close by The hide pretty well.....
the white 1 would explain why i can short the starter to start
but it wont start off the key
white plugs wires are pink and black
first two pictures are the connection for variable assist steering rack.
second one is for foglights - there will be one on the other side.
have you got the other two pin plug down near the battery plugged in? the one with the thick purple wire, and the thin brown wire? this is for starter crank and alternator light. is your battery light coming up on the dash when you turn the ignition to on?
