Hey..
Just trying to work out how 'hazards' work.. I want to experiment.. is there anything special apart from a relay, switches, lights and wires?
Could I get a wiring Diagram or such? Ive tried google but it didnt help..
Thanks
Q1 - On a VR, No.
Q2 - Turn-Signal Systems
Think of the "switch" as the thing on the steering column.
It selects a side of the car to flash. In parallel with this switch is the hazard one which selects both sides of the car.
Yeah, Think Ive got my head around it.. Last time I tried it.. I think I tried to jump into both wires with one wire that just activated both indicators next time you went to use the left indicator..
Need to get an actual switch that puts power out to both without using the same powersource.. so it wont back trace next time you use the indicators
Cheers mate
