Results 1 to 6 of 6
Thread: VN kicking but not starting
    VN Executive 3.8V6 M5
    Aug 2011
    brisbane
    Default VN kicking but not starting
    I've done an engine swap from a 93 VR to my VN. Ive hit a hiccup. Car will kick over when you turn the ignition but there is no fuel, no spark, no power to my dash or to my stereo. I've put the thing back together the exact way it was before i did the swap, now ive been to alot of different people and explained my problem and a few have said the same thing if the computer isnt in use for a few months they go into a sleep mode or something and need rebooting, I just need to know do these ecu's ever do shut down after no use or is there some other reason to my problem that im looking in the wrong place for? I just need some sort of idea before i call a sparky.
    I have put a post up previously about this problem but i have now worked out the area it is in. well i hope so someone please help.
    Aug 2011
    brisbane
    also ive run a tester to all wires from the ecu to the battery and it seems the ecu gets power but nothing seems to go further than that
    wamboin23's Avatar
    wamboin23 is offline Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    there is really no difference between disconnecting the ECU for 10 mins or 10 years.
    but if your not getting power to the stereo, dash etc, you've got more problems than an ECU - I'd be checking earths, main fuses etc.
    Aug 2011
    brisbane
    ive checked it all only power im not getting through a fuse is the fuel pump and relay. things starting to give me the shits lol
    304runner's Avatar
    304runner is offline ( .Y. )
    VR 5.0 Ute & a 4runner with a VS SS trasplant
    Mar 2011
    Central Coast NSW
    Check all the earths, mine did this when the two black wires near my coil weren't earthed correctly
    Aug 2011
    brisbane
    all good found out that i need to install a factory immoboliser back in the car simple problem. some dumbass that put the last motor in my car bypassed it. since i put a VR V6 in apparently they need to run with an immoboliser. but for safe keeping ill recheck the earths n make sure so thanks =)
  1. kicking over
    By newo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-11-2011, 11:03 PM
  2. Vn not kicking over...please help
    By johnandtrin in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-02-2009, 10:30 PM
  3. 330,000 and still kicking
    By belbelchic in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-05-2008, 11:44 AM
  4. Thermatic fan(s) not kicking in.
    By pogmahon in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-03-2007, 06:41 PM
  5. Car Not Kicking Over First Time
    By Benji in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-04-2006, 09:28 PM
